C9300X-12Y-M CLI for Troubleshooting
AxL1971
One the the Catalyst switches C9300X-12Y-M that is fully managed on the dashboard is showing offline and I am troubleshooting.
I am aware I can plug a cable into the back and navigate to basic Web interface however can I get CLI access to the switch to see any logs etc as to why the switch is unable to connect to the dashboard
Hi check it out.
Cloud CLI for Cloud-Native IOS XE - Cisco Meraki Documentation
GreenMan
Meraki Alumni (Retired)
This will, I'm sure, be a really useful tool to many, but wouldn't apply in this circumstance, where the switch is fully Meraki Cloud managed (-M) but offline to the Dashboard.    If running in monitor mode (now called Hybrid) full console access would be available locally.
rwiesmann
There is an issue raised at meraki about that Catalyst appearing offline in the dashboard.
That's probably what you are facing currently
https://status.meraki.net/incidents/zndszrwcdsx9
AlexL1
Hi All,
This incident is now resolved. All systems are performing as expected. If you continue to experience issues, please contact Meraki Support.
Posted 13 hours ago. Apr 17, 2025 - 16:50 UTC
Thank you for your patience and understanding.
Have a wonderful weekend ahead.
