Hi @DCC ,
The datasheet states a default power supply is included but no mention of the cable:
- PWR-C1-350WAC-P-M
https://documentation.meraki.com/MS/MS_Overview_and_Specifications/Catalyst_9300-M_datasheet
However, it does also state:
Package contents
In addition to the MS switch, each shipment includes the following.
- 1 x default power supply unit for the switch model (please refer to the power supply and specifications section)
- Rack mount brackets and screw kit
- 3 x Pre-installed fans.
i would say that you’ll need to order the power cables separately
