C9200CX-8UXG-2X Configuration Source: Meraki Cloud mode available?
FlyingFrames
Can i configure C9200CX-8UXG-2X using meraki cloud completely? If yes what IOS XE version will i need?
I am trying to see if in the light of this development on IOS-XE 17.18.1, this should work!
https://documentation.meraki.com/MS/Cloud_Management_with_IOS_XE/Cloud-Management_IOS_XE_Overview
Essentially i am looking for meraki dashboard configurable (not cloud CLI) fanless compact switch that can give 60W PoE. And C9200CX-8UXG-2X is the only answer i could find. Just confirming if this is possible!
RWelch
C9200CX-8UXG-2X is listed in the Cloud Management with IOS XE 17.18.1 (see link below for supported models eligible for migration).
Migration Guide
RWelch
Migration Guide
FlyingFrames
Thanks for the kind reponse. @alemabrahao @RWelch
What will be the correct license for it? LIC-MS-100-S?
Since an 8 port 9200 is not shown in this table:
https://documentation.meraki.com/General_Administration/Licensing/Subscription_-_MS_Licensing
RWelch
This is the AI Assistant response but I would double check with your Cisco / Meraki rep to be safe.
As mentioned by @RWelch, yes and you need to version 17.18.1
