I am issue COA messages to an MS-220 switch to change the VLAN. The VLAN is changing fine which is great. However, the port needs to bounce to trigger a DHCP renew. I can't seem to find anything on how to do that.
Change of Authorization is used to change client authorizations in the following use cases:
Reauthenticate RADIUS Clients Changing the VLAN for an existing client session when authentication via Wired 802.1x or MAC Authentication Bypass (MAB) is possible using CoA. A port bounce will force the client to re-authenticate and assign the new VLAN.
I tested this today using the Microsoft NPS server and having it return a new VLAN did indeed cause the port to bounce and the client got a DHCP from the new VLAN.
I tested this using firmware MS 10.18.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4e744ed954d28","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4e744ed954d28_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4e744ed954d28_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4e744ed954d28_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_4e744e767a89f","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
