Advanced Specs from MS Switches
iMikeMX
Hi
someone help me with this specs of the MS Switches (MS350 and MS355):
- DRAM Memory
- Flash Memory
- Processor
- NTP Client Support
- TACACS Support
- SNMP v3 support
- OSPFv3 Support
- Frame Switching Method, es "store and forward"?
Thks.
Inderdeep
DRAM and Flash would not be published.  And it's a network switch, so I don't know how this information would be relevant.
The processor is not published.
Meraki equipment synchronizes its time against the Meraki cloud, so there is no need for NTP client support.
There is no local console, so need for TACAS.
Everything has SNMPv3 support.
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/SNMP_Overview_and_C...
I think all switches from MS350 and above support OSPF.
KarstenI
Just two things to add:
  1. The switches do OSPFv2, not OSPFv3.
  2. The question of store and forward is somehow outdated nowadays. This marketing-battle was fought twenty years ago. All switches do Store-and-Forward nowadays, some with optimizations that are mostly not relevant in the campus. Perhaps with HFT, but there you would likely not look for Meraki.
