- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Adding Voice VLANS to multiple Ports at once
I miss the old days where I could just enter stuff into an excel sheet and then just copy paste an entire config into a terminal window.
Any who, I've got about 5 switches with about 24 ports each that need to add a voice VLAN to each port. Is there a way to do it that doesn't involve me going into the details menu of each port?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Go to " Switchports " menu. From there you can select as many ports from whichever switches you have and do your edits.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Is there something I'm missing because that's the first thing I tried and I don't see the ability to manipulate multiple VLANs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Check the "Type" drop down list from there you can choose access or trunk then VLANs I believe.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@trunolimit You maybe included some trunk ports in your selection? You can't add a voice VLAN to a trunk port, so that's why it's not visible. The "Type" field there says "Multiple Values" and type corresponds to access and trunk. Double check which ports you selected and make sure it's only access ports.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I wish Meraki would let us have access to a CLI. choices is good. Or at least let us upload a config we can alter in text.
Someone on the reddit forums said you can use python scripts to do things via the API. I might make learning python my goal for this year.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I see what the issue was. There was a trunk port hidden within all the access ports.
