Hi Team
Is there is any api to bind network access policy to a range of interfaces? I found API https://developer.cisco.com/meraki/api-v1/#!create-network-switch-access-policy to create or get the policy but I cant find the bind.
Solved! Go to solution.
This is where you apply it
https://developer.cisco.com/meraki/api-v1/#!update-device-switch-port
