802.1x Wired connection with RADIUS server authentication
Dror
Just browsing
Hello all,
I hope you be able to assist me because I'm frustrated.
I have 2 Meraki Switches MS-225 for Lan connection only. No vlans. all ports are configured on Vlan 1.
my goal is to authenticate any computer in my organization by user domain group.
I already installed RADIUS server and configured it. its located also on the same network on my Meraki switch.
I tried all the authenticated methods I have in the NPS but non of them works for me.
Test connectivity to the RADIUS server is working fine to all 4 Meraki switches.
Currently my conditions are NAS Port Type Ethernet or cable along with Domain users User Groups.
Authentication method is Microsoft: Protected EAP (PEAP).
Not sure if i select domain user group , how is the RADIUS server authenticate it ? by user creds or do I need to validates the users with certificate as well?
The problem is , once i assign the Access Policy to any port its getting red and lost connection to the client computer.
Please help me, what is the exact configuration I need to set on the RADIUS/NPS server ??
Thanks in advanced.
Dror
28 Replies 28
Check the documentation.
https://documentation.meraki.com/MS/Access_Control/Configuring_802.1X_Access_Policies_on_MS_Switches...
Dror
Just browsing
Thanks for you reply.
Yes, I tried all these docs from Meraki but unfortunatly its not helps me.
I preaty sure I need to set the right configurations on the NPS side but so far nothing works for me.
Have you checked the NPS logs?
Dror
Just browsing
I could find logs only in Event viewer but not something i could point on.
The thing is that I need to know which uthenticated method should i use for domain user authentication.
Is there other place to see NPS logs?
Check which Connection Request policy/Network policy is matching.
Cisco_CCIE
Just browsing
You need to send the radius attribute Tunnel-Pvt-Group-ID with the VLan ID when the user authenticates.
Dror
Just browsing
You mean like this ?
KarstenI
Did you edit the PEAP EAP type to set the inner Authentication method? That is not the MSCHAPv2 that is shown below that box. It has to be configured inside the PEAP config.
Dror
Just browsing
I've removed the inside MSCHAPv2. Port still disabled.😕
Check which Connection Request policy/Network policy is matching on logs.
KarstenI
WHAT did you remove? You have to make sure to have the right inner method.
Dror
Just browsing
And what are they ?
these my current Authentication methods:
KarstenI
Likely the "Secure Password". Did you add it?
Dror
Just browsing
it was there before. it didnt help. port still get disable
if you sure it has to be there i will add it back.
Do I need to use any certificate in order to authenticate the users ?
KarstenI
The certificate shown in NPS must be trusted on the end devices.
You really should get a consultant to help you. 802.1X is one of the most complex topics and is especially hard with NPS.
Guys the problem is that it's not matching with any connection policy.
 It's very common, create a new connection policy with the the same configuration that you create in the network policy.
Dror
Just browsing
I dont have User Group under connection request policy like I have in Network Policy
I don't remember exactly what the config should look like, but this might help.
Dror
Just browsing
I tried many consultants before i posted here. 😉
Where can i see the certificate in the NPS ? Couldnt find it.
Really? Don't have a certificate installed? You need an MS Windows server expert.
https://learn.microsoft.com/en-us/windows-server/networking/core-network-guide/cncg/server-certs/ins...
Dror
Just browsing
OK but non of the logs i get says something about certificate..
This is the basics of 802.1x.
https://learn.microsoft.com/en-us/previous-versions/windows/it-pro/windows-server-2012-r2-and-2012/h...)
KarstenI
If the connection request policies are messed up, it doesn't even get to the point where the certificates are relevant. When looking at the screenshot above, it seems that you assigned the root cert to the NPS. Let's say this is as least "unconventional".
Dror
Just browsing
Any change on NPS configuration bring a different logs. I dont know what are the right configuration i need to set.
this is the latest logs I've received:
Network Policy Server denied access to a user.
Contact the Network Policy Server administrator for more information.
User:
Security ID: NULL SID
Account Name: host/TACCPC333.claimscon.org
Account Domain: -
Fully Qualified Account Name: -
Client Machine:
Account Name: -
Called Station Identifier: 08-F1-B3-34-3F-94:
Calling Station Identifier: 70-B5-E8-3A-31-E7
NAS:
NAS IPv4 Address: 192.168.250.51
NAS IPv6 Address: -
NAS Identifier: -
NAS Port-Type: Ethernet
NAS Port: 5
RADIUS Client:
Client Friendly Name: TA Switch LAN 1
Client IP Address: 192.168.250.51
Authentication Details:
Connection Request Policy Name: -
Network Policy Name: -
Authentication Provider: -
Authentication Server: TACCDC19.claimscon.org
Authentication Type: -
EAP Type: -
Account Session Identifier: 31394546453945463246324638364531
Logging Results: Accounting information was written to the local log file.
Reason Code: 49
Reason: The RADIUS request did not match any configured connection request policy (CRP).
You need to create a connection request policy.
Dror
Just browsing
sure but i already have one configured.
Dror
Just browsing
s there any configuration needed to do on the endpoint ? NIC configurations?
🤔https://www.virtualizationhowto.com/2018/12/configure-windows-10-for-802-1x-user-authentication/
