Search instead for
Local LAN Addresses
Local LAN Addresses
We deploy MX64s that have names that allow me to easily parse the location where it resides. Most of them use one of a handful of templates.  The managed computers at a location have SCCM on them and I can see the LAN address that they are using, but I don't know where they are.  What I am trying to achieve is to locate the computers based on the unique subnet issued by the MX64.  Using the API I can easily pull all of the MXs on our network, and I can see their WAN addresses, but I don't see a way to tell what DHCP pool range the device is using when handing out addresses on the LAN side, or even it's LAN address even though there is a field for that, it does not have a value.
I have written a script that loops through all the devices and then all the clients but that is tedious and very time consuming.  Is there a more efficient way to get this info?  Is there a setting on the template that is stopping the "lanIp" field from being populated?
Accepted Solutions
Re: Local LAN Addresses
Which API endpoint are you using? This should give you what you're looking for:
https://api.meraki.com/api_docs#list-the-vlans-for-an-mx-network
2 REPLIES 2
THANK YOU SIR!  I don't see how I missed that function. That gives just what I need.
