Search instead for
Get Networks returning 404
I'm new with Meraki API and so far the only working GET so far is about my organizations, but when I try to get the network (using the ID retrieved from the previous get), the response i 404
https://api.meraki.com/api/v0/organizations/xxxblablablaxxx/networks ]
Why? the Organization ID is correct...  I also tried with a sample Org_ID I found on Meraki Postman start guide, and it works of course. So, is it due some missing permission? What should I check?
Thanks!
Accepted Solutions
Re: Get Networks returning 404
Does your account have full access at the organization level (not at the network level)?
5 REPLIES 5
Make sure the Dashboard API is enabled for your organization.  Go to Meraki Dashboard > Organization > Settings.  Look for the "API Access" setting.
Already enabled, I also generated a brand new key and used in the place of the first key.
The GET Organizations is the only one working...  Y_Y
I think that is it. If I give myself "None" in organization and "Full" for the specific network then I can list my orgs, but can't actually fetch the networks.
Bingo... I have Read Only permission, indeed. I though that simple GET request would have been allowed, at least.
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
