While I was experimenting with motion capture for some apparently unimportant contest, I found something which I think may be a bug. When I downloaded the motion capture images, they automatically get a .jpg extension. However the file itself is using the .png file format. While Windows seems to not care about this, other applications not so much. The photo upload here on the community for example throws a fit, as well as photo editing software on my PC.
Have any of you experienced the same? If yes, let me know so I can inform the product team about the bug.
Cheerz!
