Meraki Display On Apple TV - Error Accessing Videowall
RAID5
Hello, wondering if anyone else has come across Meraki Display On Apple TV - Error Accessing Videowall
For context we have maybe 10 or so of these deployed at different sites.
Occasionally they come up with Error accessing videowall - cannot get value of type string, found null value instead. Underlying error the data could not be read as it is missing
This happens randomly and most of the time going back a couple of times on the remote will fix the problem.
Sometimes though it maybe hours before it starts working again.
No issues seen on the switch ports or anything like that.
Raid 5
oliviaaaaa
This usually happens when the Apple TV briefly loses connection to the Meraki Display. Try using the remote to update. This should help.
RAID5
Thanks very much for the reply!
I will give this a try and see how we get on.
tiffwalker
Yes, I had this too. It's more likely a temporary issue with the Meraki backend or app syncing, rather than a network outage. Try restarting the Meraki Display or Apple TV apps. Since a full update of the app and tvOS helps reduce the frequency of such situations.
BlakeRichardson
I have no experience with Meraki display however I do have experience with AppleTV's and I have found that apps which stream video i.e. Plex, Netflix etc seem to lose connectivity at times requiring you to exit to the menu and in some cases restart the entire device.
