MV73X install
Karl_Jacobsen
MV73X install
Hi all,
       I'm installing my first MV73X camera and I'm a little confused as to the use of the 12V line. The 73X has the normal RJ45 line for power/data but it also has a 12V line that connects to a screw type connector marked 12VDC. Is the for additional heating of the unit in cold temps? The install guide doesn't seem to mention it.
This is because this camera supports Wifi, so you can use the power supply and connect via Wifi, without the need to use a network cable.
10 Replies 10
You can use either one, you don't need to use both types.
Also, if you have a legacy camera deployment using coax cables, you can  run the power along the coax and use a "MV Low Voltage Power Adapter (LVPA)" to power the camera.
https://documentation.meraki.com/MV/Physical_Installation/MV_Low_Voltage_Power_Adapter_(LVPA)_Instal...
Karl_Jacobsen
So is the 12VDC line to power the camera like the PoE would? I'm having an issue with snow accumulating on the camera, especially overnight. I can address this by trying to add a shield around the mount but it's tricky....20250106_081214.jpg20250106_081223.jpg
Exactly.
Karl_Jacobsen
Got it.... we'll have to find a way to shield it. Thanks!
There are sprays you can put on the dome for water to run off, these might also help with snow.  I think @Ryan_Miles has used them and commented elsewhere.
Ryan_Miles
Meraki Employee All-Star
Might have been this comment from another Merakian
Thanks @Ryan_Miles, indeed it was @GreenMan and RainX does state that it helps keep snow off as well 😎
