MV with Brivo Access Control Solution
Steve_Panton
Does anyone know if the MV devices are compatilable with Brivo Access Control Solution?
GreenMan
Meraki Alumni (Retired)
There's no specific functionality built for that integration from the Meraki side.   From a brief look on the Brivo side, it appears they have some documented interoperability -  https://help.brivoworkplace.com/articles/cisco-meraki-integration
This does seem to basically involve Brivo solely using Meraki WiFi for uplink though.   Based on the available REST APIs on both sides, I suspect there's a lot more could be done with MV cameras, via some kind of middleware.  I guess it would help if you defined what you want to achieve?
Brivo do not appear to be a signed up Meraki ecosystem partner:  https://apps.meraki.io/en-US/home
At least  - not yet...   And I don't have any experience personally with them - but open APIs is definitely the Meraki approach to interop generally - that's in good part why it's there!
Bear in mind that Cisco do offer a free trial process where you might be able to test this for a time, without any initial outlay (at least on the Cisco side)
1 Reply 1
GreenMan
