MV camera template support
Andre_S
Just wondering if anyone knows if more support for templating of cameras is on the roadmap?
I have tested creating a template configuration using the API and copying a camera only network. It works and the template is created but there doesnt seem to be anything that can be done with it at the moment.
The other thing that would be nice is to have cameras integrated into Combined configuration templates so that a separate network site is not required for cameras. Hopefully there is some good news on the horizon...
Omkar_Manjrekar
@Andre_S
Currently, configuration templates cannot be used on networks with Systems Manager or MV Cameras, but we should soon have the feature incoming.
Meanwhile, I would suggest submitting a feature request about the same by using the "Make a Wish" button on the Meraki Dashboard.
Regards,
Meraki Team
2 Replies 2
Omkar_Manjrekar
@Andre_S
Regards,
Meraki Team
Andre_S
@Omkar_Manjrekar thanks for the reply and information. Can't wait to be able to consolidate sites further.
