I've run several MVs wirelessly only for years here at home. What model MVs? And what APs are you using? Meraki? Not that it should really matter. Also, running latest stable firmware?
How about the SSID config? What security mode is being used? PSK, 802.1X, etc.? How about RF related settings? Min bitrate, load balancing, 2.4 and 5 GHz enabled?
Are other devices connected to these same APs? Are they having issues?
Also, you mentioned either rebooting AP or unplugging? You mean unplugging AP or Camera? Just looking for clarity on which side (AP or client/MV) is being rebooted? Line of thought being is the Camera reboot the fix or the AP reboot.
My setup - I have nearly every model MV running here on wireless. Two wired APs, two mesh repeaters (MR56s and MR44s). I've used PSK, 802.1X, WPA2, WPA3, and now doing MAB with Access Manager. Connectivity is always fine.
