Live video with object detection
xamatgar
Is there any way to get a link of the Meraki live video with the yellow boxes (with the objects detected)? Thank you in advance
GreenMan
Meraki Alumni (Retired)
You could use motion alerts, via Webhook, to trigger the capture of footage:
https://documentation.meraki.com/MV/Advanced_Configuration/Motion_Alerts#Alert_Only_on_People_Events
https://developer.cisco.com/meraki/api-v1/#!get-device-camera-video-link
There's a beta tool available to trigger such alerts only on people detection too.   Right now I don't believe that extends to vehicles.    Bear in mind that if you also triggered the capture of screen grabs, you could send the output to AWS Rekognition (for example) which could detect vehicles, people, text and all sorts of other things.
You may also find MV sense particularly useful in pre-processing and adding more granular information:   https://meraki.cisco.com/lib/pdf/meraki_datasheet_mv_sense.pdf
5 Replies 5
GreenMan
No - object detection is performed post-capture.
xamatgar
So, there is no API to extract the video with the detections even post-capture right?
GreenMan
GreenMan
If you're looking to consume something existing, rather than 'build-your-own' - maybe explore what's already available in the Marketplace?    https://apps.meraki.io/apps/?meraki-product-integration=Meraki%20Cameras
You can use MQTT and it sends you the rectangle coordinates for every object in the frame.  You can then draw the rectangle on top of the image yourself.
This is the specific MQTT reference:
https://developer.cisco.com/meraki/mv-sense/#!mqtt/raw-detections-a-list-containing-object-identifie...
