Keep Vision Portal Up 24x7
DirectorMxF
We have set up various MV cameras both internally and externally to one of our facilities.  As part of that we set up a large TV and Windows PC to show all of cameras via the Vision Portal.  The problem is that overnight the session (or communication to the cameras) "times out" and the browser goes completely white.  Is there a way to have it so the PC, browser and portal all stay up 24x7? It should be noted that it does run without issue all day long 8+ hours (so it isn't that the PC is going to sleep/hibernating).
2 Replies 2
Have you thought of using an Apple TV, as the app is designed specifically for continuous monitoring?
double_virgule
I don't recommend leaving an open session to your Vision Portal running unsupervised overnight. If you don't have anyone monitoring overnight, then a better and more secure solution would be to have them log in when they first come in, as it sounds like the portal runs without issue during the workday (8 hours).
