Is it possible to use Meraki camera for recongizing numberplates and opening a garageport?
Sondre
I was wondering if someone have tried to use meraki camera to recongizing numberplates and then have a way to open up a garage port?
The solution is for a apartmentbuilding where the goal si that every owner of a car have the possbility to drive into the garage with "zero thouch"
1 Reply 1
I did quite a bit of work with licence plate recognition in the distant past.  I used Plate Recognizer because of their native Meraki support.
https://platerecognizer.com/camera-integrations/meraki/
You then use their API, and they call your web hook with the number plate seen.
I'm not aware of any "off the shelf" solutions - but that is half the problem solved above.  Make sure you use a camera that supports recognising cars.  I would take a look at the MV73X.
You could also search the Meraki App Marketplace for existing solutions.
https://apps.meraki.io/en-US/home
