Hide Faces
AndreasK
Hide Faces
I have a privacy issue with a customer here in Austria.. We are not allowed to show the faces on the video. So we tried to put some filters on the dome to make the faces irrecognizable. This works but now the camera does not count people. Do you know if it is possible to "hide" faces and count people?
Are there any other solutions available?
We are using the new MV12.
I have talked to our Meraki contact here in Austria, but it seems that this is not on the roadmap....Why?
Other manufacturers have implemented this feature.
Thanks for the information!
Regards
Andreas
1 REPLY 1
Adam
Can you record normally and then just run the export through a tool that filters the faces before utilizing any video?  In the event you had to turn it over to an agency etc.
Or are you not even allowed to record video with faces?
