Green bar in timeline missing
Dunky
I have noticed across all of my sites that the green bar at the top of the timeline is no longer showing.....
Is everyone else seeing the same?
I have checked across multiple cameras at multiple sites and they are all the same.
Unsure as to when this started.
The recorded video is still accessible though.
btw, It shows ok in the Vision Portal, just not in the Dashboard.
The bar is back for me on n199, @Dunky is your's okay now?
Ryan_Miles
Meraki Employee All-Star
Seeing the same on all my Cameras. I'd suggest opening a Support case so Eng can check it out.
Dunky
Will do, thanks Ryan
Dunky
Hi cmr, Yes all back as normal this morning.
I guess Meraki fixed summat at the back end.
I will close the case I opened with them.
