I have 5 MV72 Cameras outside my Building, paid a lot for these cameras and I cant even focus on a License plate 50' away from the camera, Anyone have any help on this issue, or are these cameras just not good.
Quantum
What firmware you on? get to the latest if you're not on it.
Thank you , yes Firmware is the latest version
A license plate 50' away may be a little ambitious... There's no license plates in the view of mine right now so I can't try and do the same thing.
for the cost of these cameras, I would be embarrassed to not have that capability, i found 200.00 cameras that will zoom and focus on this exact detail.
Have you adjusted the zoom on the cameras?
I did, and Called Support on the phone and they accessed the cameras and Said its the best its going to be, But i cant believe that these cameras aren't capable of clear readable zooming
I've setup an MV72 at a range of about 15m and can keep the number plates ok. I tested a snapshot with openalpr.com and it was able to recognise the number plate as well.
I can't decide if I should post the picture as it is not my number plate, so to err on the side of privacy and caution I have decided not to.
However below are the settings I changed. I set:
