Facing issues with my MV wireless camera
mia01
Just browsing
A few weeks ago, I installed a brand-new MV12N in my clinic. As a hair transplant specialist, I have much to do in my clinic, but I check the footage every chance I get. However, for a few days, I noticed that the footage had become distorted and blurry. I'm trying to figure out the reason, but still no avail. Can someone help me?
5 Replies 5
I suggest you open a support case.
Here is a link that may help you, but I still recommend opening a support case.
Troubleshooting and Replacing a Faulty MV - Cisco Meraki Documentation
BlakeRichardson
Have you tried autofocusing the camera?
There is no autofocus on an MV12 (fixed lens).  But good thinking.
Can you see anything unusual when you visually inspect the camera?
I think I would take a gentle cloth (maybe microfibre) and try cleaning the lens.  I am most suspicious that something has gotten on it.
Being in a medical setting, it's possible that some chemical has been heated, vaporised, and re-condensed on the lens.
Next thought, in desperation, try to power cycle the camera (unplug it and plug it back in again).
Next thought, in even more desperation, try upgrading the firmware.
Trying to think more laterally - image quality is affected by lighting.  Does it make any difference if you turn more lights on (if that is even an option)?  Is there any chance you are using less lighting than before?
tiffwalker
The most common causes of blurry or distorted video on your new MV12N camera are network bandwidth issues, incorrect resolution settings, or a dirty lens. You may want to check your camera settings and network connection.
