Customized Object Detection MV72X
CSMax
Hi, my company is using MV72X and I like to know if we can deploy a customized deep learning model (other objects), other than the built-in people and object detection.
Thanks!
No.  I've made this feature request before.  I don't think the security teams would allow it either.
You can use MQTT and the snapshot API to trigger when it sees motion, retrieve a snapshot, and then process that.  This can be done from the cloud.
https://developer.cisco.com/meraki/mv-sense/#!mqtt
https://developer.cisco.com/meraki/api-v1/#!generate-device-camera-snapshot
You can use the RTSP interface and process on-premise (I guess you could stream to the cloud if you didn't mind the bandwidth consumption).
https://documentation.meraki.com/MV/Advanced_Configuration/External_RTSP
2 Replies 2
CSMax
Thanks for the reply @PhilipDAth. And it makes sense from the security point of view.
