Camera MV21
akrammeraki
Camera MV21
Hello all,
I need information about how many bandwidth and connection speed used for one camera MV21 ?
Best reagrds
Akram
3 REPLIES 3
damienleick
Yeah it depend if you're watching all the day.
If not, and not using cloud storage I think the bandwidth usage is minimal
MerakiDave
Hello @akrammeraki  an MV21 is 720p and at enhanced quality and 15 frames/sec, it should put a bit less than 800Kbps onto the network if you are actively viewing video from that camera.  But when you're not viewing video, all storage and analytics happen on the camera and only things like motion indexing information and Dashboard communications should amount to 1 or 2Kbps on an MV21, as mentioned in the other posts referenced.
Hope that helps!
