- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MT20 not finding MR42 as gateway
Hello. I had my MT20 sensor working previously with the same MR42. The only difference is they are now both in a new network. When I press the button on the MT20 I see the LED cycle through the rainbow colors and it stops on amber for a few seconds then shuts off. It never connects to the MR42.
I also see the sensor will occassionaly activate on it's own, presumably looking for a gateway. I'd like to know how frequently it does this as I won't physically be at this location much longer.
Can you tell me how I can troubleshoot this further? I've been looking on the MR42 (Dashboard -> Wireless) settings and cannot find anything indicating a connection to the sensor.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
https://documentation.meraki.com/MT/MT_Installation_Guides/MT_Troubleshooting_Guide
I'd check a few things if it was working fine previosuly;
- Doesthe new network have different firmware settings being applied to the MR access point? Is this set to 26.7+ Fimrware?
- Is the MR access point being powered by the same power source? If not check to ensure the AP is running in full power mode. (Instructions in the KB article attached will help)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
When you moved the MR to this new network did you also make sure to set it for the latest beta 28.5 release? MR42 needs to be on 28.x to support the MT's.
A newly created MR network would default to the current stable of 27.7.1 and that doesn't support the MT connection with older Wi-Fi 5 AP's like the MR42.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the responses. I had no idea firmware could rollback when moved to a new network. I updated the firmware in the new network and it's now working fine!
