MT15 Sensors
rodeddie
MT15 Sensors
 I have a site that currently has a Sensaphone IMS-4000E Enterprise Monitoring Host installed, and they are interested in the MT15 sensors. The question they asked is if the IMS-4000 can send alerts to the Meraki sensors in case it detects smoke.
Regards
GreenMan
Meraki Alumni (Retired)
I'm rather confused by this ask;   MTs are IoT sensors;   they are not a management system in themselves - you can't send alerts to them.   So the MT15 might well send it's own alert, if a fire happened to cause any one of the  parameters it monitors to exceed a configured alert threshold.   Bear in mind though - MT15 is not a smoke detector, nor is it designed for such 'life-and-death' use cases.   This is why we describe it as an air quality sensor.
Bear in mind the MT sensors rely on the Meraki Dashboard (and interconnecting Meraki APs / MV cameras as BLE gateways) as the means to report on the parameters they measure.  So, for example, if an MT15 detects that the temperature has exceeded a configured threshold, it alerts to the Dashboard in the first instance.   This can also then result in emails or webhooks ecternally.   This could also be supplemented via MQTT-based monitoring.
5 Replies 5
GreenMan
rodeddie
Thakk you both for your feedback.
I've considered various scenarios of what could be asked here, but each time the answer was "no".
NewNothing
It would be great if there was a profile setting for a smoke/fire detector on the MT15's. I have brought this up in a few calls and webinars, but maybe it is just not possible.
BlakeRichardson
I would not recommend relying on a wifi based IOT sensor for fire protection, get a proper hard wired system that is serviced regularly.
Our fire protection system sends me an SMS when a panel is activated and when it's been restored. Had a callout on Wednesday just been and response time from fire service was 11 mins from activation to panel reset.
