MT11 Sensor probe alternative ?
Thygesen
Hi All !!
I know this is a sensitive subject..
But if I were (for some reason) to measure something OUTSIDE the limits of the probe(s) orderable with the MT11 (ie high temperatures or the like), is there a way to get specs to get a custom built sensor manufactored, that fits to the MT11 ?
Ok, i understand.  Making your own would not be recommended and I would advise reaching out to your Cisco Account team and/or Cisco Meraki team to talk about this as a Feature Request so we can track the use case and develop this kind of solution.
3 REPLIES 3
Larry_Woods
Do you mind elaborating on your use case or problem you are trying to solve for?
Thygesen
Hi Larry ..
Challenge: The probes only allows +55 Celcius as max ..
Situation: If ie we were to monitor outlet from heating systems, boilers etc. reaching temperatures way over the limits of the provided probes ..
And it would be a shame not to use these MT's since we deploy wall2wall Meraki ..
