Hello everyone,
Does anyone know if I need to quote the probe cable for the MT11 sensor separately, or if it comes with the sensor in the main package? I'm confused because I don't see the cable listed in the package contents in the installation guide :
MT11 Probe Sensor Installation Guide - Cisco Meraki Documentation
Thanks.
MariamT
Solved! Go to solution.
you have to quote the probe. You have the choice between baremetal and glycol probe.
MA-CBL-TEMP-ME-1
Bare Metal Temperature Probe
MA-CBL-TEMP-GL-1
Glycol-Encased Temperature Probe
Thank you @Christophebe !!
