API call to MT40 to switch it on and off
KingArthur
Good day
Can someone show me what the API string looks like that power the MT40 up and down?
I am experimenting with Node Red.
I have a MV2 that sends a signal to a MQTT broker.
When there is movement then a API call must be made to the MT40 to switch it on.
If no movement is detected in 5 minutes then it must switch the MT40 off.
Thanks in advance!
Greenberet
I'm not sure if the node-red package is up 2 date and have the api call, but you would need this one https://developer.cisco.com/meraki/api-v1/create-device-sensor-command/
Thanks bud! I will have a look!
I actually managed to switch the MT40 on and off with a python script, so Im making progress!
