vMX100 Azure VPN
DTheMan
vMX100 Azure VPN
Hello Everyone,
I am new to vMX100 and Azure. I have sucessfully configured vMX100 in Azure and configured Client VPN setup. I am able to connect to VPN but I am unable to ping any Azure vnets/servers. Can anyone point me to the right direction to resolve the problem?
4 REPLIES 4
JHO
Under site to site VPN on the Azure vMX, did you add the routes you want advertised?  Did you add a route in your Azure gateway for your remote subnets to be pointed to the virtual appliances IP - i.e. next hop?
MarcG
Did you configure the Azure Route table ?
you will need to configure this and associate this to your subnet.
in the route creation:
subnet needs to be the one of your local network and next hop the wan local ip of the vMx
I was able to resolve the problem after peering the two vnets and checking allow forwarded traffic.
johnn2244
I know this is a late response to this thread, but figured I'd ask.
How were you able to create a client VPN to the vMX100? I've had some issues getting that to work with Windows client. I have a mesh site-to-site up and running just fine, but cannot do a client VPN nor a (Non-meraki) site-to-site. I manage several customers, but this one is the only one with a vmx100 in Azure. I am pretty fluent in setting up client VPNs to MX100s and MX84s. Any recommendations or experiences would be appreciated. Thanks!
