BGP best-path selection algorithm on Meraki MX one-armed concentrator
CSV
Does anyone have Meraki documentation related to BGP best-path selection algorithm?
From my testing environment I've noticed that a MX in one-armed concentrator mode (the only mode that supports eBGP) always prefers the eBGP route over iBGP route (it doesn't care of AS-PATH length)
Ex:
R1(AS 100)----eBGP----HUB1-----iBGP(AS 65100)-----HUB2----R2 (AS 200)
R1 advertises subnet 10.10.10.10/32 with AS path 100 100 100
R2 advertises subnet 10.10.10.10/32 with AS path 200
--> Hub1 prefers the external route from R1 (would expect to prefer the route from Hub2)
--> Hub2 prefers the external route from R2 (expected behavior)
--> If R1 stops advertising 10.10.10.10/32, then Hub1 will receive the route from Hub2 via iBGP with AS PATH 65100 200
--> If Spoke 1 has in the hub list HUB1(primary) HUB2(secondary), it will prefer the route from HUB2 with AS PATH 65100 200
thanks
CptnCrnch
CSV
Hi CptnCrnch,
My post is not related to your link.
thanks
I haven't seen any documentation covering the BGP path selection process.
MarcoSch
Do have a look at the following CiscoLive 2018 presentation: BRKCRS-2103 Integrating the Meraki SD WAN Solution with the traditional Enterprise network. The presentation covers several subjects including BGP based path selection for a one-armed concentrator.
The presentation and recording should be available via ciscolive.com
Regards,
Marco.
