vMX100 Azure Deployment
eezee
I would like to seek help on the deployment of vMX100 in Azure.
Here are my steps:
- Went to Marketplace
- Searched for Cisco Meraki vMX
- Create
- Filled up Resource Group, Location, Authentication Token, App Name
- On the next part, I cannot choose my existing Virtual Network as it was greyed out.
For isolation purposes, I tried creating a new vnet and was able to choose the created vnet.
For some reason, I cannot choose the existing vNet that contains some of my VMs.
4 REPLIES 4
I don't know the answer.
Is the existing VNET really old, perhaps some kind of legacy VNET?
eezee
The vNet was created 2 months ago and it's not legacy. If I am going to create a new vNet, that vNet is clickable. Unfortunately, the others were not.
For the below configuration, I should choose aCloud-vNet but it is greyed out.
I don't know why the VNet is greyed out.  You might need to open a case with Azure support.
eezee
Already found the solution and now working.
I did a custom template deployment and a guide is listed below:
https://documentation.meraki.com/MX/Installation_Guides/vMX100_Setup_Guide_for_Microsoft_Azure#vMX10...
