syslog messages delivered by webhook
Shaun1387
Hi All,
I had read somewhere in the Meraki documentation (which i cant seem to find again...) that syslog events should also be sent as Webhooks.
Can anyone confirm that this is possible (or not!) as i cant get it to work, and i cant see any obvious switches or places where it would be configured.
This is for an MX running 16.16.4 code.
Cheers All !
Shaun
GreenMan
Meraki Alumni (Retired)
To my knowledge we've never had that capability.    Most customers would simply use syslog directly, with an appropriate syslog server in their central off network location - perhaps with a secure tunnel between the two, to carry the syslog traffic.
7 Replies 7
Brash
There's some basic documentation on webhooks. Not sure if it's all syslog events or some dashboard alerts though:
https://documentation.meraki.com/General_Administration/Other_Topics/Webhooks
GreenMan
Yes - webhooks are about alerts, rather than events.   You can pull the event log though, via the Dashboard API:   https://developer.cisco.com/meraki/api-v1/#!get-network-events
Shaun1387
Cheers GreenMan !
So I have my webhook destination set up and working, the test webhook seems to work ok and im getting webhooks through ok for the alerts I have configured under configure->alerts.
What i really need is for syslog messages to come in via webhooks as well, I have an MX on the network which is happily generating syslog messages locally but I need them in a central , off network location and they arent currently coming through on webhooks at the moment. VPN between the local LAN and the remote site isnt an option nor is exposing a syslog to the internet.
am I right in now thinking that this isnt possible via Webhooks?
The documentation seem contradictory (if only i could lay my hands on the doc that said it was possible...doh!)
Thanks again for your help
Cheers
GreenMan
Shaun1387
Thanks Again GreenMan,
That clears that up for me. The VPN option would be the 'goto' in any other environment but its not really going to work in this case.
Another option, if such a thing exists...., may be to find and deploy a local Syslog server to site which has an HTTP Push capability, see if the messages can be relayed that way.  Actually, that might be quite a neat solution.🤔
Thanks again for clearing that up for me, If i find something suitable i will post back up here.
Cheers
Shaun
Shaun1387
Hi WW,
yeah, i think it may have been that one. 🤔
