subnet not reachable from split tunnel VPN client
TEAM-ind
Hello.  I hope everyone is doing well.   I am seeing a behavior when adding a subnet to our LAN.  Each of our locations has an MX appliance.    192.168.102.0 /24 is newly added network at one location, and it is reachable from all locations and from VPN clients.  However, when I split tunnel a VPN client, it is not reachable.  I cannot figure out why.  Other local subnets are reachable when using split tunnel, but not this newly added one.
Can anybody provide a reason as to why that might be the case?
Have you tried adding the route to the network manually?
netsh interface ipv4 add route <destination subnet> "<interface name>"
https://documentation.meraki.com/MX/Client_VPN/Configuring_Split_Tunnel_Client_VPN
TEAM-ind
Hello, and thank you for your reply.
Yes, that does work, but I am wondering why I need to do that, as I do not need to for other local networks.
Because it is necessary to specify the traffic that goes to the VPN manually as described in the documentation, for this it is necessary to create the entry manually.
