site-to-site tunnel connection details on MX
BrentB
Relatively new to the Meraki word and the MX devices. We created a site -to-site tunnel with an MX in another organization. The users have reported issues accessing resources on our end and trying to see what details we can get on the link. The VPN status usage & Latency on the MX seems to be an overall and seem to be unable to drill down into details on the specific peer link. Have I just been missing where to look?
9 Replies 9
RWelch
Site-to-Site VPN Troubleshooting
BrentB
That is just it .. everything for a single day or for the past week has all been green. Thee are other Meraki devices such as Z1s or Z3s that are connected and have nothing from those end users. I was hoping to be able to isolate the specific tunnel and see if it would give me any usage or latency details as they say high latency would cause the issues they are facing.
RWelch
If you go into the VPN status page and select the PEER status it will show latency (avg) for that VPN.
RWelch
Is there data flow to/from the MX Z appliances?  Seems odd if they are active that you have no visibility on their status.
tnco
Is your VPN connection normal?
If it is not normal, there may be a problem with the uplink, so you need to troubleshoot according to the documentation.
https://documentation.meraki.com/MX/Site-to-site_VPN/Meraki_Auto_VPN_-_Configuration_and_Troubleshoo...
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-Site_VPN_Troubleshooting
Uplink historical data is also useful for investigating the uplink. If the results are bad, you will know that there is a problem with the uplink.
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Appliance_Status/MX_Uplink_Settings#His...
BrentB
As far as we know the tunnel is working fine. I have green lights for status and I can ping across it. We just had someone come to us saying the access to our ERP system was seeing excessive errors and the errors they are seeing happen on lesser quality networks. They were asking for a review of packet loss and latency across the link. I unfortunately only have visibility of this side of the link as the other side is in a different organization.
RWelch
Have you enabled the HUB local resources they are trying to reach remotely (VPN mode ENABLED)?
Dashboard > Security & SD-WAN > Configure > Site-to-Site VPN under VPN Settings (Local Networks)?
A common issue with MX when using IKEv2 is that only a single (source,destintion) subnet combination can be active at a time.  So if you have 3 subnets in the first org and 4 in the second, of the 12 combinations only 1 can work at a time.  IKEv1 doesn't have this issue on MX.  Consider using IKEv1 if you are not already.
If one of the orgs has a lot of sites, a more scalable solution is to get an additional MX and run it in VPN concentrator mode.  Add it to org1, and install it behind a hub MX in org2.
In org2, and static routes pointing to the org1 MX behind it, and distribute those into AuvoVPN.
In org1, and "local routes" to the VPN concentrator sitting inside of org2.
Then all spoes (and hubs) can talk to all other spokes (and hubs).
RWelch
Good to know info, now I'm going to go back and look to see if my site connections are v1 or v2. 🤔🤔🤔
