site to site VPN Meraki MX64
munaf
I have issue with site to site vpn need some assitance to fix this issue.
as i have 3 sites
site 1 has connectivity with site 2 & site 3 but
site 2 has connectivity with just site 1
site 3 has connectivity with just site 1
site 2 & site 3 has some connectivity issue between
Please support me to fix these issue
4 REPLIES 4
Site 2 and 3 are configured as vpn Hub?
munaf
yes
kordm
When you select the Network for Sites 2 or 3, does the subnet for the other site appear in the Route Table for that MX?
Select Network for Site 2. Go to Security & SD WAN > Route Table. Does the subnet for Site 3 appear in the list?
Under Site-to-Site VPN settings, do you see Site 3 and its subnet listed in the "Remote VPN participants" list?
Are there any rules defined under the "Site-to-site outbound firewall" section?
If you do a traceroute from a host in Site 2 to a host in Site 3, what happens?
munaf
yes config is OK but the problem is connectivity is not stable sometimes it is up and sometimes goes down
