s2s vpn between Meraki and Non Meraki
Did Someone had this issues? how to solve it? andy advise, thanks
I was doing some test using auto vpn  in Meraki  in a small topology  { Meraki 64 ( Branch )  -----MX 100 ( Hub ) ----- Non Meraki ( ASA /Fortigate ) }
Local network in  MX 64 (192.168.0.1/24) ( BRANCH) -----> (vpn) ------> MX 100 ( HUB) -----> non-Meraki (ASA/Fortifate) Network 172.16.0. 1/16)
+ VPN work with no problem between Meraki Branch and Meraki Hub.
+ as well VPN was up and working between Meraki Hub and Non-Meraki device ( ASA/ Fortigate).
The problem was between the Branch Meraki and Non-Meraki,  I was NOT able to reach the network behind Non-Meraki in both directions from/ to the Branch MX64 , I mean from 192.168.0.1/24 in the MX 64  i cannot ping/reach  172.16.0.1/16  in the Non-Meraki device. & VPN is up and running ( ph1 and ph2 ).
  I have been advised that We need to have a Meraki in the Far end before the None Meraki so it will be able to reach that Network.
  Is this a limitation in the VPN?  do we have an alternative solution for this issues  ( I want to reach the far end remote end Network in
 Is this a limitation in the VPN?  do we have an alternative solution for this issues  ( I want to reach the far end remote end Network in non Meraki device ( ASA/Fortigate)  from the Branch MX64   which is connected to the MX100 using VPN and the MX100 is connected to the None Meraki through a VPN also?.
Accepted Solutions
Re: s2s vpn between Meraki and Non Meraki
@Senan_Rogers 3rd-party VPN routes are not advertised into the AutoVPN route table and there is no way to do so unfortunately.
A common workaround when you need to merge both AutoVPN and 3rd-party VPN route tables is to use two different MX appliances as hubs:
1. DC MX1, that's in your main org and terminates your Meraki AutoVPN domain.
2. DC MX2, which is in a dedicated org you create just for terminating 3rd-party VPN.
Then on DC MX1, simply configure a static route for any of the remote, 3rd-pary VPN destinations with a next hop of the inside IP of MX2. The same can be done in reverse on MX2, with a default route pointing towards your MX1 or your DC core.
9 REPLIES 9
Can you build the VPN from the two Meraki's to the non-Meraki - rather than only from the hub?
That will make things much simpler.
Hello ,
Thank you ,  I have 43 Branch Sites , and all of them are connected to Mx 100 ( Hub) and then for Temp. need to be connected to the Non-Meraki (ASA cisco).
If I will connect  those 43 Branch sites  as VPN S2S to the cisco ASA  ,then I will have 43 VPN s2s connection, Not easy to Maintenance it
Any other advice.
Thank you
Did you check from 'Security Appliance > Addressing & VLANs' if you have below configs:
- route created from MX64 (Meraki Spoke) towards ASA/FG (non-Meraki Spoke). It should be dest: 172.16.0.1/16, gw: MX100 IP from 192.168.0.1 subnet
- if the route is advertised by selecting 'Yes' for 'In VPN'.
Screenshot added FYR.
I'm not confident that is going to work.
Normally the site to non-Meraki site VPN is for subnets directly connected to the MX in question (and which you have specifically enabled).  I am not confident you can build the VPN to routes sitting in its routing table.
What I did for one of my customers is put in a little ASA 5506 beside their MX hub.  I added static routes on the ASA 5506 to get to all the remote MX's via the hub MX.  I then added a route to the MX hub for the remote VPN via the ASA 5506 and included this in the AutoVPN.  I then built a VPN between their 5506 and the remote non-Meraki VPN peer.
They actually had a few more complex site to site VPNs as well, include one that needed a NAT - so the ASA 5506 was the only "nice and clean" solution for them.
Perhaps this might be an option for you as well.
Hello ,
Thank you for your reply,  I have found two alternative solution , But those two solution will need to add  one more device. Very Similar to your solution.
Solution # 1
I will Connect an ASA cisco in front of MX100 and will connect both  asa cisco ( vpn s2s)  , So it will be :-
MX 64 -----> mx 100 ----asa ----------> asa
Solution #2
 I will use another MX100  in front of the ASA Cisco ,  in this case it will be  Mx 64 ----> mx100 ----> mx 100 ----asa cisco
But  I am looking to see or find why we cannot have a two hope VPN connection like the other products ?  To me this is similar to the max hope in RIP  protocols ( max 16 hopes ) then no more routing.
In our case it seems Meraki cannot send traffic with two VPN connection if one of them is Non-MERAKI.
Can you do this style connection (my preferred option)?
          Internet
       MX            ASA
         Inside network
Hello ,
Thank you for your idea, It's very similar to my idea as well . It will work also, But the Question was why we cannot send traffic from  Meraki ------- Meraki ---------Non Meraki  ?
Do you face the Same Problem ?
I don't know. I'm not saying it wont work, but I am not very confident that it will. Adding an ASA 5506 will be rock solid reliable though.
