ping across S2S
leadtheway
ping across S2S
Have about 6 sites setup in mesh. All show connected, but when i use the live tool to ping test pcs on other sites it does't respond. Is there something i need to do to get that to work?  I can ping all the subnet gateways.
NolanHerring
Do you have anything else you can try to ping that isn't a computer (with potential firewall causing issues)?
Nolan Herring | nolanwifi.com
TwitterLinkedIn
6 Replies 6
NolanHerring
Sounds like the computer firewalls are not allowing ping maybe?
TwitterLinkedIn
I'm with @NolanHerring - sounds like Windows Firewall.
Can you ping the MX LAN IP's over AutoVPN ok?
leadtheway
I'll double check but I believe firewall is off..  If i hop on the MX and use the ping tool i can ping all the other gateways at other sites for the other subnets that are advertised across the vpn
leadtheway
also checked the MX firewall rules and icmp is allowed
NolanHerring
TwitterLinkedIn
leadtheway
yeah i have a print server i could ping.  That worked...so def. a windows firewall/SEP issue.. thanks for the help
