Search instead for
ping across S2S
ping across S2S
Have about 6 sites setup in mesh. All show connected, but when i use the live tool to ping test pcs on other sites it does't respond. Is there something i need to do to get that to work?  I can ping all the subnet gateways.
Accepted Solutions
Re: ping across S2S
Do you have anything else you can try to ping that isn't a computer (with potential firewall causing issues)?
Nolan Herring | nolanwifi.com
TwitterLinkedIn
6 REPLIES 6
Re: ping across S2S
Sounds like the computer firewalls are not allowing ping maybe?
TwitterLinkedIn
Re: ping across S2S
I'm with @NolanHerring - sounds like Windows Firewall.
Can you ping the MX LAN IP's over AutoVPN ok?
Re: ping across S2S
I'll double check but I believe firewall is off..  If i hop on the MX and use the ping tool i can ping all the other gateways at other sites for the other subnets that are advertised across the vpn
Re: ping across S2S
also checked the MX firewall rules and icmp is allowed
Re: ping across S2S
TwitterLinkedIn
Re: ping across S2S
yeah i have a print server i could ping.  That worked...so def. a windows firewall/SEP issue.. thanks for the help
