Have about 6 sites setup in mesh. All show connected, but when i use the live tool to ping test pcs on other sites it does't respond. Is there something i need to do to get that to work? I can ping all the subnet gateways.
Solved! Go to solution.
I'm with @NolanHerring - sounds like Windows Firewall.
Can you ping the MX LAN IP's over AutoVPN ok?
I'll double check but I believe firewall is off.. If i hop on the MX and use the ping tool i can ping all the other gateways at other sites for the other subnets that are advertised across the vpn
also checked the MX firewall rules and icmp is allowed
yeah i have a print server i could ping. That worked...so def. a windows firewall/SEP issue.. thanks for the help
