- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
non-internet connected network connected to WAN2 on mx100 says 'Failed'
Hi There,
I'm in the process of replacing a fortinet 60D gateway with an MX100. The fortinet has 2 wan ports, 1 connected to the internet and the other to another subnet which has some dedicated lines to data services hosted on it. Wan2 is not connected to the internet.
Setting up WAN1 (internet connection) on the MX100 using a static IP was not problem and worked straight away. When I set the static IP for wan2 the Meraki dashboard tells me that the connection failed, and I can't communicate with devices on that subnet despite WAN2 having the same address/mask/gateway address as was on the fortinet.
Has the WAN2 connection genuinely failed or is it just saying it's failed as it's not able to connect to the internet? Is there a way to tell why it failed?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Worked like a treat. Cheers bayet!
