meraki 20.x code
Joel75
Just browsing
meraki 20.x code
how do i get on the early testers list for mx20.x code?
You need to consult your Meraki sales representative.
Joel75
Just browsing
i have and so far nothing on that end.
Mloraditch
You may be a bit early.  19.2 is still in beta and hasn't had a single update yet. I'm not even sure I've seen anything under NDA in my partner events about 20.x
Regardless if you are a customer your AM is the primary route. Occasionally Cisco has done public betas for certain features that you can sign up for and those posts have been here in the community.
Blue_Bird
Hello @Joel75
In order to get on the early testers list for Cisco Meraki MX 20.x firmware, you’ll need to opt in through the Meraki Dashboard or contact Meraki support directly.
