http traffic
SanderB21
http traffic
Hi All,
We have updated our MX to the latest verion MX 18.107.2 last friday since then we are experience some issues with http traffic someone experience the same issues? I don't see any blocks in our firewall and syslog is enabled
Kind Regards,
Sander
SanderB21
Hi @DarrenOC thanks for your reply, i've contacted Cisco aswell and they said it's a change with the web cache we need to disable but need to restart and that's not possible so we are scheduled this for this evening let you know if it solves the problem.
DarrenOC
Hi @SanderB21 , what issues are you experiencing?  Do the issues clear if you revert back to the previous MX release?
SanderB21
DarrenOC
Thanks for the swift reply @SanderB21 .  Please do let the community know the outcome.
SanderB21
Issue is solved by disable web cache option and reboot the appliance
