found repurpose MX67 - need advice
Anonymous
Not applicable
Hi, I recently purchasd a SDwan Cisco Meraki MX67 from an electronics store still works however still learning about cloud control. what do i need or acquire to make this work from my home lab? I have 2 ISP internet connections one cable and other fiber. do i need a license ? how do i manage the device from the cloud. I have already accessed it from the local dashboard page .
thanks for any advice.
11 Replies 11
Brash
The high-level things you need to do are:
1. Create a dashboard account and add the device SN# to the inventory.
NOTE: If the previous owner has not released the device from their dashboard account, you are stuck. There is no way you will be able to use the device.
2. Create a network in the dashboard and add the device to the network
3. Purchase an MX67 license and add it to your dashboard. If you don't purchase a license, the device will disconnect from the dashboard in 30 days.
There's plenty of guides and docs for getting started:
Getting Started with Meraki - Cisco Meraki Documentation
Getting Started Checklist - Cisco Meraki Documentation
Anonymous
Not applicable
this is true and i realized that luckily i did not pay too much for it.
where do i create a dashboard account ?
how much is a license off the top of your head?
can this device handle Dual WAN ?
Yes, it can load balance two WAN connections, however as stated by @Brash, if you cannot add it to the dashboard, you cannot do anything useful with it.
DarrenOC
Kudos to the above from @Brash .  Fingers crossed you haven’t purchased yourself a nice little doorstop.
Anonymous
Not applicable
Hi Again, ok I was ablet to get the merkai sd wan installed and adopted in my dashboard and it works well, i have not delved into the settings from DB cloud as of yet , i did receive an email on licensing info. Also this device was never used in a production environment as the meraki dashboard indicated to me woo hoo. however that is what brings me back the LICENSE purchase what is this going to cost.  This is only for my home lab / home lan that i use for work, computer use, gaming console use, media streaming, etc. thanks for any advice.
DarrenOC
Hi @Anonymous , do you need the sd-wan license?  It’s going to cost you around £500+
https://www.broadbandbuyer.com/products/44056-meraki-lic-mx67-sdw-1yr/
If it’s just home use look at the ent license instead
DarrenOC
Try Insight
https://www.insight.com/en_US/shop/product/LIC-MX67-ENT-3YR/cisco%20systems/LIC-MX67-ENT-3YR/Cisco-M...
You can change the license term if the 3 year one is a little pricey to start with.  Also, do you have the mx67 or mx67w?
Anonymous
Not applicable
it is the MX67
Anonymous
Not applicable
how funny i work for insight - however i dont think they give employee discounts not sure
DarrenOC
Throw in the word NFR - (not for resale)
Anonymous
Not applicable
Hi Darren, thanks so much, I will need a license for this device?  i am in the States does that matter?
I do not have a enterprise environment only for home use which license do i require. thanks
