create Fixed Ip address assignments on MX bound to template
VincentDumont
Hi All,
I want to create 150+ Fixed ip address assignments. on networks bound to templates. the link Import CSV is not available on this bound network.
What is  the fastest way to add these?
It is a requirement of my network management team, they will not monitor unless a DHCP fixed ip address assignment has been created.
1 Reply 1
Crocker
You can cycle through each individual network with the scripting language of your choice, via the API, and set DHCP reservations using the following endpoint: Update Network Appliance Vlan - Meraki Dashboard API v1 - Cisco Meraki Developer Hub
