convert license to per-device license
SopheakMang
Dear expert ,
i want to convert co-terminate license to per device license,
Could you explain me how to do that ?
for example i buy 10 license , they would give me one license cover 10 devices, so if i convert will the license be generated to 10 different license too ?
i'm not sure on that
2 REPLIES 2
BrechtSchamp
There's no difference between co-termination and per-device licenses. It's the same SKU.
Whether it's applied as one or the other depends on the organization that it's applied to.
When converting to per-device licensing the process will generate per-device licenses for every existing license in the organization. After the conversions, licenses are just applied as per-device licenses immediately.
The links provided by @CptnCrnch should help explain more.
