Log in Meraki dashboard for MX
SopheakMang
Dear Expert
we got some question from our customer ,
1.How long will the log store in meraki dashbord ? such as change log ?
2.How can we check VPN policy log match , for example : match deny rule , where can we see the log action deny by MX.
3.where can we check security log ? For example , if someone trying to access to MX devices by trying to login to local splash page, is there any alert or log on dashboard ?
pls help answer this
1 Reply 1
BrechtSchamp
1. Regarding the retention Aaron Willette wrote an excellent blog post:
https://www.willette.works/meraki-event-logs/
I don't know how up-to-date it is though.
Perhaps it's time @CameronMoody turns this into an official doc 😇.
2. Seems to me like only succesfull logins are logged in the event log. You can find them in Network-Wide > Event Log. Syslog provides more detail:
Succesful connect and disconnect in green.
Connection try with a wrong username in red.
Connection try with a wrong preshared key doesn't seem to get logged at all.
3. Login tries to the local status page (not sure that that is what you mean) aren't logged.
