I'm trying to set up the client VPN using Active Directory Authentication but i have this error
Solved! Go to Solution.
Have you followed all the steps? Check the part that talks about certificate requirements:
still not work i do all
i creat certificate on dc same the topic still not work
i enable this serv and it work thx
So, the certificate was not installed. 🙃
