We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
I'm trying to set up the client VPN using Active Directory Authentication but i have this error
Solved! Go to solution.
i enable this serv and it work thx
Have you followed all the steps? Check the part that talks about certificate requirements:
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Configuring_Active_Direc...
still not work i do all
i creat certificate on dc same the topic still not work
https://helpdesk.kaseya.com/hc/en-gb/articles/229041128-EMM-AD-Integration-Fails-with-Error-Error-in...
So, the certificate was not installed. 🙃
